[Nokia Lumia 820] Sujet général
Après avoir annoncé son haut de gamme sous Windows Phone 8, Nokia a aussi annoncé le Lumia 820, un Windows Phone milieu de gamme qui remplacera le Lumia 710.
Un milieu de gamme certes, mais celui-ci est doté d’un écran de 4.3 pouces et d’un appareil photo de 8 mégapixels, ainsi que de la même technologie de recharge sans fil que le Lumia 920.
Spécifications :
  • Écran 4.3 pouces (800×480) AMOLED
  • Processeur Dual Core 1.5GHz
  • 1Go RAM
  • Appareil Photo 8 Mégapixels Carl Zeiss + flash LED
  • Enregistrement vidéo full HD 1080p
  • Caméra frontale VGA
  • Bluetooth & NFC
  • Slot Micro SD
  • Mémoire flash 8Go
  • Batterie 1850mAh
  • Dimensions
  • Coques interchangeables
  • Couleurs disponibles : Noir, Blanc, Gris, Cyan, Rouge, Jaune, Violet
Le Lumia 820 sera disponible en France …. au prix de
source: NokiaTouch
The Nokia event in New York is in full swing and the second phone the Finnish company announced is the Nokia Lumia 820. It has a smaller screen than the 920 flagship and it misses out on a few of the cool new features, but should provide the same solid smartphone experience.
The Nokia Lumia 820 has a 4.3" AMOLED display of WVGA resolution (no HD, sorry), which features the ClearBlack technology. It does have the same super sensitive touch like the 920, which allows it to work with gloves, but misses on the PureMotion HD+ fun.
The phone uses the same polycarbonate unibody design and will have optional protective shells you can put on the back.
Nokia Lumia 820
The Nokia Lumia 820 will run Windows Phone 8 (of course) and will be powered by the same Qualcomm S4 chipset as the 920, with a dual-core Krait processor clocked at 1.5GHz and 1GB of RAM at its heart. Nokia says it's up to 30% more power-efficient than "competing quad-core designs" (we assume it means the 45nm Tegra 3). For the record, teh 820 has a 1650mAh battery.
The Lumia 820 is compatible with the wireless charging Fatboy pillow (you need a protective shell for that) and it has 8GB of built-in storage (and 7GB of SkyDrive cloud storage). Unlike old Windows Phone handsets, the 820 has a microSD slot too, so you're free to expand that as you like.
What the Lumia 820 misses, compared to the Lumia 920 is the PureView camera tech, but it still has a Carl Zeiss lens and an 8MP sensor. The Lumia 820 will take advantage of the new camera features that Microsoft just announced.
The LTE connectivity is on board, along with the new and exciting NFC-based features of Windows Phone 8.
The Nokia Lumia 820 measures 123.8 x 68.5 x 9.9mm and weighs 160g. It will be available in several different colors.
pas vilain non plus !
En marge de son prochain vaisseau amiral que va être le Lumia 920, Nokia a également dévoilé le Lumia 820. Il s'agit d'un autre smartphone sous Windows Phone 8, mais aux caractéristiques un peu plus modestes. Si le design global semble assez proche de celui du Lumia 920, les angles sont ci un peu plus adoucis, moins marqués. Les dimensions de la bêtes sont de 123,8 x 68,5 x 9,9 mm pour 160 g.
L'écran est lui aussi moins huppé puisqu'il dispose des mêmes caractéristiques que ceux des précédentes générations de Windows Phone avec une diagonale de 4,3 pouces et une résolution de 800 x 480 pixels. Comme le Nokia Lumia 900 donc. Là où il s'en démarque en beauté, c'est avec son chipset double coeur Qualcomm Snapdragon S4 cadencé à 1,5 GHz et doté d'un 1 Go de mémoire vive (RAM).
Quant au capteur photo, même s'il n'est pas estampillé « PureView », il affiche tout de même 8 mégapixels, une optique Carl Zeiss et se montre capable de filmer en Full HD 1080p. Pour le reste, le smartphone est lui aussi compatible avec la norme Qi qui va permettre de recharger la batterie de 1650 mAh de manière sans fil.
Le Lumia 820 sera certainement plus abordable que le Lumia 920. Impossible toutefois d'être catégorique dans la mesure où le constructeur n'a daigné donner ni date de disponibilité, ni prix pour ces deux nouveaux produits...
http://www.lesmobiles.com/actualite/8599-nokia-lumia-820-un-milieu-de-gamme-sous-windows-phone-8.html
Le Nokia Lumia 820 est un smartphone élégant de milieu de gamme qui offre des performances haut de gamme dans un boîtier compact. Doté du même design monocorps que les smartphones Lumia haut de gamme, le Nokia Lumia 820 est livré avec des coques interchangeables. Celles-ci permettent non seulement d'égayer l'appareil avec une palette de coloris, mais également de bénéficier de la fonction de charge sans fil. Un emplacement est en outre prévu sous la coque pour l'insertion d'une carte mémoire MicroSD.
Windows Phone 8 comme système d’exploitation
Windows Phone 8 permet aux utilisateurs de vivre une expérience plus personnelle avec leur smartphone, grâce à un écran d'accueil plus facile à personnaliser en fonction des priorités de chacun et à de nouvelles vignettes dynamiques animées proposant des mises à jour en temps réel des informations auxquelles ils attachent le plus d'importance. La possibilité de synchroniser le contenu entre les smartphones Windows Phone 8, les ordinateurs et tablettes sous Windows 8 ou les Xbox permet à l'utilisateur d'accéder à ses fichiers, sa musique, ses photos et ses vidéos à sa propre convenance. En outre, grâce à Internet Explorer 10, qui garantit une navigation plus rapide et plus sûre, et aux applications Microsoft Office intégrées dans la plate-forme, Windows Phone 8 simplifie comme jamais l'exécution de différentes tâches.
Des partenaires pour la charge sans fil
Nokia a annoncé la conclusion de divers partenariats, ainsi que la commercialisation d'une série d'accessoires de charge sans fil. Parmi ceux-ci figurent le coussin Fatboy® Rechargeable, une solution cool et design pour recharger le smartphone, ou encore la JBL PowerUP, une station d'accueil de charge sans fil au design rétro qui offre un son de haute qualité et est proposée par JBL.
Nokia a d'ores et déjà conclu des partenariats avec Virgin Atlantic en vue d'installer des stations de charge sans fil dans les salons du London Heathrow Clubhouse et avec la chaîne Coffee Bean & Tea Leaf en vue de placer des plateaux de charge sur les tables de certains cafés. Il s'agit là des deux premiers partenariats sur les nombreux que compte nouer Nokia afin de rendre la charge sans fil accessible en dehors du domicile et du bureau.
Disponibilité
Le Nokia Lumia 820 est quant à lui disponible en rouge, jaune, gris, cyan, violet, blanc et noir. Les deux smartphones seront disponibles sur des marchés sélectionnés dans des variantes LTE et HSPA+ pentabande et devraient être commercialisés plus tard dans l'année.
Nokia publiera les tarifs et les dates de déploiement pays par pays dès que la date de mise en vente sera fixée.
Spécifications des téléphones
Nokia Lumia 920
Nokia Lumia 820
Écran
Écran LCD IPS Nokia PureMotion HD+ WXGA 4,5 pouces
Écran tactile « Super Sensitive »
Nokia ClearBlack avec mode luminosité élevée et amélioration de la lisibilité en plein soleil
Écran OLED WVGA 4,3 pouces (800x480) avec technologie ClearBlack
Batterie
2 000 mAh avec charge sans fil Qi intégrée
1 650 mAh avec prise en charge de la charge sans fil Qi intégrée
Processeur
Snapdragon S4 double cœur de 1,5 GHz
Appareil photo principal
8,7 mégapixels avec technologie de stabilisation optique Nokia PureView et optique Carl Zeiss
Capture vidéo Full HD 1080p à 30 images/s
8 mégapixels avec autofocus et optique Carl Zeiss
Double flash LED
Appareil photo avant
1,2 mégapixel avec capture vidéo HD 720p
VGA
Mémoire
RAM de 1 Go
Mémoire de 32 Go avec 7 Go de stockage SkyDrive gratuits
RAM de 1 Go
Mémoire auxiliaire de 8 Go avec prise en charge des cartes mémoire microSD et 7 Go de stockage SkyDrive gratuits
Source: MonWindowsPhone
http://youtu.be/aIYm07ACkjU
Plutôt mignon le Lumia 820 mais la résolution de l'écran est plus faible que la plupart des Androphones. :papy:
En plus il est lourd je trouve. 160g pour 4,3". Bon après ça vient peut-être de la batterie. :unsure:
Nokia annonce les dates et prix des Lumia 820/920 pour l’Italie !
On y est presque pour la France, et ça commence à se préciser de plus en plus pour les pays frontaliers, puisque Nokia a annoncé officiellement lors d’un communiqué de presse les dates et prix pour la sortie du Lumia 820 et du Lumia 920 en Italie.
Les mobiles seront disponibles mi-novembre, au prix de de 499€ pour le Lumia 820 et 599€ pour le Lumia 920, chez les principaux opérateurs / revendeurs italiens (Telecom Italy, Italy Three, Vodafone et Wind).
On attend maintenant que Nokia France communique là dessus pour vous transmettre les dates et prix pour la France, mais ça devrait être assez similaire à ce qu’ils ont annoncé pour l’Italie ! icon_smile.gif
source: Nokians
Le porte-parole de Nokia nous propose de découvrir le Lumia 820. Prévu pour la mi-novembre, ce terminal fait partie des deux premiers mobiles Nokia sous Windows Phone 8. Par rapport au Lumia 920 (voir vidéo de prise en mains), ce terminal de moyenne / haute gamme présente la particularité de disposer d'une coque arrière interchangeable.
La séquence présente les attributs physiques du téléphone, et fait le point sur les principales nouveautés (dévoilées) de Windows Phone 8. Le changement est-il radical par rapport à Windows Phone 7 ? Comment se passe l'execution d'une application Window Phone 7 sur Windows Phone 8 ? Monsieur De Horts nous éclaire sur ces différents points.
0280016805468649-photo-clubic-4-prise-en-mains-du-nokia-lumia-820-sous-windows-pho-479677-422257-854x480-5-jpg.jpg
Après avoir réalisé des démonstrations vidéo des mobiles, Nokia nous propose de découvrir l'ensemble des accessoires optionnels qui seront proposés pour l'un et l'autre de ces smartphones Windows Phone 8. Au programme, rechargement sans fil, NFC et équipements audio Bluetooth.
0280016805468657-photo-clubic-4-les-accessoires-destines-aux-lumia-820-et-lumia-92-479682-422259-854x480-4-jpg.jpg
La suite sur Clubic.com : Prise en mains vidéo du Nokia Lumia 820 sous WP 8, et présentation des accessoires http://www.clubic.com/os-mobile/windows-phone-8/actualite-517137-lumia-820.html#ixzz29fcPuvbu
Informatique et high tech
Testé hier car un employé viens d'en acheter un et bien bonne surprise l'écran est très bon aussi ainsi que la fluidité.
L'Apn est un peu moins bon que le Lumia 920 mais largement au niveau des smartphones concurrent... Pour le reste ça reste exactement pareil sauf qu'il est un peu moins lourd mais quand même largement plus lourd que la concurrence mais pour une finition quand même bien au dessus...
Bref un bon produit et plus abordable que son grand frère ... Maintenant faudrait que Nokia communique un peu plus dessus au niveau de la pub car il y en as que pour le Lumia 920 pour l'instant
Un test du Lumia 820 est disponible sur mobiles-actus.com (page 1/5)
La conclusion :
Les Plus "+" :
  • Chargement sans fil
  • Technologie NFC
  • Windows Phone 8
Les Moins "-" :
  • Chargeur sans fil en option
  • 160 grammes
  • Ecran 480 x 800 pixels
  • 3 months later...
