[MeeGo] Tablette ou Smartphone Nokia sous MeeGo
We just dug out a photo of a Nokia-branded MeeGo tablet, along with some specs. Packing telephony and a landscape-oriented interface we are not sure what to make of the device, but it might just turn out to be the hotly anticipated Nokia N9. The device pictured is obviously a really early prototype as most of its hardware is not working and there is none of the Nokia custom UI to be seen on it. Yet we did get some hardware specs so its not all bad.
Packing a 4.5-inch screen the Nokia MeeGo half-tablet-half-phone will be supporting 3G with HSDPA, Wi-Fi and Bluetooth. A microUSB port is not mentioned but its now mandatory for all devices sold in the EU so I will assume its present too. An accelerometer is onboard, along a gyroscope. Camera is also present, though we cannot confirm its resolution. If this really turns out to be the Nokia N9 and previous rumors are to be trusted we might get to see the N8 top-quality on this one. Of course, there is always the chance that this is just a reference design for engineering needs and we are getting all too excited without a valid reason.
Looks like I was right when I said that the MeeGo tablet will be out on April... Stay tuned with us to see the Upcoming MeeGo tablet that will be announced Soon and releasing on April.[/Quote]
Source: Youmobile.org
effectivement... mais que des rumeurs !
voilà ce que dit MaemoFrance à propose de ces images qui à priori font beaucoup parler...
Que peut-on vraiment dire de ce cliché ? Franchement pas grand chose, surtout au vue de sa qualité (mais n’est ce pas là le propre des « leaks »). La seule chose que l’on peut réellement voir c’est une partie de l’interface de MeeGo (dans sa version 1.2, d’après le bugtracker) avec l’apparition du clavier virtuelle, de la configuration réseau et du lecteur multimédia (dont une partie est encore bugguée d’après les résultats d’un test proposé sur le site de meego.com)
Une personne du forum mobile-review a joué sur la luminosité de la photo afin d’avoir un meilleur rendu des contours de l’appareil présenté.
Là les choses se précise un peu et on peu donc spéculer un peu : déjà, à l’inverse des derniers appareils Nokia mis sur le marché, le logo a été centré horizontalement alors que l’appareil, à l’instar du N900, est apparemment optimisé pour une utilisation au format paysage. On peut également voir sur le côté droit, une petite partie caoutchoutée… serait-ce le bout d’un stylet ? Également, d’après certains blogs, si on considère que le logo Nokia est normalisé (notamment par rapport à celui présent sur le N8), alors on peut penser que la taille de l’écran est de 4,5 pouces. D’autres pensent que l’écran peut faire entre 5 et 10 pouces. En somme, l’imagination va bon train avec notamment des suppositions de ce que l’on pourrait trouver au cœur de l’appareil (un processeur Intel Medfield, la prochaine plate-forme Atom optimisée pour les tablettes/smartphones, 1 Go de Ram ?).
On peut en tout cas espérer une annonce de la part du constructeur Finlandais à propos de ce nouvel appareil au sein de son offre au prochain Mobile World Congress se déroulant à Barcelone du 14 au 17 février prochain ou peut-être même avant.
Que pensez-vous de toutes ces rumeurs autour des appareils sous MeeGo qui commencent à enfler au travers d’internet à l’approche de l’événement majeur que représente le MWC ?
source: MaemoFrance
Apparemment la rumeur qui a fait le tour de la planète ce week-end serait issu d’un partenariat entre Nokia et ST-Ericsson (fabriquant de processeur SoC basé sur la technologie ARM -- System on Chip). En effet, c’est encore un membre de mobile-review qui a fait remonter l’information et qui a vu des similitude avec la plate-forme intégrée à destination des smartphones de dernière génération U8500 de ST-Ericsson. On retrouve ci-après une photo comparative proposé par Cor72z, membre du forum mobile-review.
Il faut savoir que le U8500 est une plate-forme haut de gamme animé par un bi-processeur ARM Cortex A9 1,2GHz basé sur la technologie SMP (Symmetric Multi-Processing). Cette technologie permet une gestion avancée de l’alimentation en équilibrant le travail entre les processeurs et « down-clockant » (réduire la fréquence de fonctionnement) les processeurs lorsque ces derniers ne sont pas sollicités. Est aussi intégré dans cette plate-forme le dernier GPU de la famille ARM, j’ai nommé Mali 400 associé à l’extension processeur NEON® (qui permet de prendre en charge une partie de l’accélération matériel au niveau des médias et du signal).
Tout ceci permet à ce petit monstre de pouvoir encoder (enregistrement) et décoder (lecture) nativement des flux vidéos haute définition de 1080p ainsi que plusieurs codecs audio. Il gère également un affichage en XDA (1 024×768) et ce, en multi-écran ! Il supporte évidemment l’accélération 3D avec la gestion d’OpenVG 1.1 et OpenGL ES 2.0. Mais ce n’est pas fini, il peut prendre en charge deux caméras, une de 18Mpxl et une de 5Mpxl ce qui ouvre certaine opportunité quand à de la visio-conférence en haute définition par exemple. A cela s’ajoute les divers connexions tels que le WiFi, Bluetooth, GPS, USB 2.0, HDMI et un support optionnel pour la TV sur mobile.
Enfin, l’optimisation de l’énergie serait telle qu’avec une batterie de 1000 mAh il serait possible d’écouter de la musique pendant 120 heures ou bien regarder de la vidéo en haute définition pendant près de 12 heures !
Alors, est-ce que Nokia aurait décidé de mettre les petits plats dans les grands et nous proposer une roadmap basée de la plate-forme la plus performante (à ce jour) du marché ? Qu’en pensez-vous ?
Sources: MaemoFrance & Engadget.com
Voici une vidéo (en anglais) qui permet de voir un peu mieux à quoi ressemble la plate-forme de ST-Ericsson. Noter l’information donnée à la fin de la vidéo qui permet de confirmer quelque peu les dernières rumeurs.
Pour moi une tablette ne remplacera jamais un netbook. Comment surfer sur Internet, lire un document Word et papoter sur MSN avec une tablette ? Je considère qu'un objet à plus de 400€ qui ne sert qu'à surfer ou presque, c'est un gadget. :laugh:
