Nokia C2-02
Nokia C2-02 review: A simple touch
Introduction
As Nokia smartphones struggle to hold the line against the storming droids, more and more pressure falls on their feature-phone squad. It will be up to those foot soldiers to buy enough time for the heavily armed Windows Phone 7 reinforcements to arrive.
The Nokia C2-02 is the first of a trio of handsets to try and make the most of what's probably Nokia's last remaining stronghold - simple to use phones with good looks and an attractive price tag. The Touch and Type series has been doing well for Nokia and even though they scrapped the name, the spirit will live on.
To get us started, here's what the C2-02 is all about:
Key features
Dual-band GSM/GPRS/EDGE support
2.6" 256K-color resistive TFT QVGA touchscreen
S40 6th edition
2 megapixel fixed-focus camera
QCIF video recording at 15fps
Stereo FM radio with RDS, Visual radio
Bluetooth v2.1 (with A2DP)
Standard microUSB port
microSD card slot (32 GB supported, 2GB included)
3.5mm audio jack
Extra smooth and precise haptic feedback
Attractive price
Main disadvantages
No Wi-Fi
Doesn’t charge off USB
No screen brightness control
No document viewer
No smart dialing
No video-call camera
No accelerometer sensor means no cool features like tap-for-time and turn-to mute
No multitasking
suite ici : gsmarena.com
