-Philippe- Posté(e) le 24 septembre 2011 Signaler Posté(e) le 24 septembre 2011 Motorola DROID RAZR with QHD A tantalizing new Motorola smartphone has just leaked through the taps of the interweb. Called Motorola DROID RAZR, the device is packing some serious kit in that sleek Kevlar and Gorilla glass body. First of all, it has a 4.3-inch QHD display, but it's not your run-of-the-mill LCD but a Super AMOLED display. There is a good chance that it will be a PenTile-matrix display but most people couldn't care less about the underlying technology when the actual image quality happens to be eye-poppingly good. Other specs include 4G LTE support, dual-core 1.2GHz processor, 1GB RAM, 8 megapixel camera with 1080p video recording and image stabilization, HD front camera and support for Motorola's WebTop accessories. The design looks really attractive and being a RAZR it should be really thin as well. The DROID nomenclature suggests it will be available on Verizon, although there could be a version for other networks and markets (called the Spyder). For more information, check out the source link below. gsmarena.com Citer
Caro 7610 Posté(e) le 24 septembre 2011 Signaler Posté(e) le 24 septembre 2011 Merci pour l'info Philippe. :D Quand j'ai lu "Razr" j'ai aussitôt crû au retour du téléphone à clapet façon pelle à tarte. :) Citer
Davidsic Posté(e) le 18 octobre 2011 Signaler Posté(e) le 18 octobre 2011 Mmm sympa ce new Moto -> Motorola announces the DROID RAZR, slimmest smartphone yet sur gsmarena.com Citer
-Philippe- Posté(e) le 19 octobre 2011 Auteur Signaler Posté(e) le 19 octobre 2011 GENERAL 2G Network GSM 850 / 900 / 1800 / 1900 CDMA 800 / 1900 3G Network HSDPA 850 / 1900 / 2100 CDMA2000 1xEV-DO /LTE Announced 2011, October Status Coming soon. 2011, November SIZE Dimensions 130.7 x 68.9 x 7.1 mm Weight 127 g DISPLAY Type Capacitive touchscreen, 16M colors Size 540 x 960 pixels, 4.3 inches (~256 ppi pixel density) - Gorilla Glass display - Multi-touch input method - Accelerometer sensor for UI auto-rotate - Proximity sensor for auto turn-off SOUND Alert types Vibration, MP3, WAV ringtones Loudspeaker Yes 3.5mm jack Yes MEMORY Phonebook Practically unlimited entries and fields, Photocall Call records Practically unlimited Internal 16 GB storage, 1GB RAM Card slot microSD, up to 32GB, 16GB card included DATA GPRS Yes EDGE Yes 3G Rev. A, up to 3.1 Mbps, LTE, HSDPA, HSUPA WLAN Wi-Fi 802.11 b/g/n, DLNA, Wi-Fi hotspot Bluetooth Yes, v4.0 with LE+EDR Infrared port No USB Yes, microUSB v2.0 CAMERA Primary 8 MP, 3264x2448 pixels, autofocus, LED flash Features Touch-focus, geo-tagging, face detection, image stabilization Video Yes, 1080p@30fps Secondary Yes, 2MP, 720p videos FEATURES OS Android OS, v2.3.5 (Gingerbread) CPU 1.2 GHz dual-core Cortex-A9 CPU, PowerVR SGX540 GPU, TI OMAP 4430 chipset Messaging SMS(threaded view), MMS, Email, Push Email, IM Browser HTML Radio Stereo FM radio with RDS Games Yes Colors Black GPS Yes, with A-GPS support Java Yes, via Java MIDP emulator - Splash resistant - HDMI port - SNS integration - Digital compass - Google Search, Maps, Gmail - YouTube, Google Talk, Picasa integration - MP3/AAC+/WAV/WMA player - MP4/H.263/H.264/WMV player - Organizer - Document viewer/editor - Voice memo/dial/commands - Predictive text input BATTERY Standard battery, Li-Ion 1780 mAh Stand-by Up to 204 h Talk time Up to 12 h 30 min gsmarena.com Citer
-Philippe- Posté(e) le 20 octobre 2011 Auteur Signaler Posté(e) le 20 octobre 2011 Le Razr, prochain smartphone phare de Motorola, sera disponible à partir de novembre en France chez SFR. Avec le Razr, Motorola remet aux goûts du jour un nom chargé d'histoire et de succès pour la compagnie américaine. L'annonce européenne de ce nouveau smartphone n'a toutefois rien d'une surprise dans la mesure où il a été dévoilé quelques heures auparavant aux États-Unis, sous le nom de Droid Razr. Il s'agit évidemment des deux mêmes mobiles, à quelques détails près. Le nouveau smartphone est très mince et léger. Doté d'une façade en verre sculpté avec des touches aluminium, le Motorola RAZR est équipé d'un boîtier en KEVLAR et en verre Corning Gorilla particulièrement résistant aux rayures. En fait, le constructeur précise que chaque élément du smartphone est protégé par un revêtement étanche, y compris les circuits électriques à l'intérieur du téléphone. Pour le reste, voici un rappel de sa fiche technique : • Une épaisseur de seulement 7,7 mm aux points les plus fins • Un écran 4,3 pouces Super Amoled (540 x 960 pixels) • Un processeur double cœur TI cadencé à 1,2 GHz • Une grosse batterie de 1780 mAh • Un capteur photo capable de filmer en 1080p • Le support du Bluetooth 4.0 • 16 Go de mémoire interne La déception vient du fait que c'est Android 2.3.5 qui fait tourner ce smartphone alors qu'Android 4.0 va être disponible en même temps dans le Samsung Galaxy Nexus. Mais le constructeur a déjà fait savoir qu'une mise à jour était envisagée pour début 2012. Notez que le Motorola Razr intègre l'application Motorola MotoCast qui permet de lire ou de télécharger du contenu directement depuis votre ordinateur sur votre téléphone portable. Enfin, le constructeur va proposer toute une gamme d'accessoires avec ce smartphone. Avec le kit Work and Play, il suffit de brancher l'appareil à la station multimédia HD pour le raccorder à un grand écran plat, à des enceintes et à d'autres périphériques pour en profiter sur grand écran. En outre, le clavier et la souris dotés de la technologie Bluetooth permettent d'utiliser l'application webtop de Motorola pour éditer des documents et surfer sur le Web grâce à un navigateur Firefox complet. Le nouvel utilitaire Smart Controller offre la possibilité de contrôler le contenu sur grand écran, sans risquer de manquer des appels quand l'appareil est posé sur sa base Enfin, les nouveaux Motorola Lapdock 500 Pro et Lapdock 100 font du Razr un véritable ordinateur portable. Les deux versions proposent un clavier intégré mais diffèrent par la taille de l'écran, de 14 pouces pour le 500 Pro et 10,1 pouces pour le 100. Dans les deux cas, il suffit de brancher dessus le Razr pour regarder des films, éditer des documents, passer en mode chat vidéo avec la webcam intégrée et surfer sur le Web grâce au navigateur Firefox complet. Le Motorola RAZR sera disponible en France à partir de novembre, tout d'abord chez SFR. Aucun prix n'a en revanche été communiqué pour l'instant. lesmobiles.com Citer
Saga Posté(e) le 20 octobre 2011 Signaler Posté(e) le 20 octobre 2011 En tout cas il me fait bien plus envie que le Nexus Galaxy, l'écran sera un peu plus petit avec une réso pas trop petite mais pas top non plus. Mais le design et les matériaux utilisés... C'est ce qui avait faire le succès du tout premier RAZR que j'avais beaucoup aimé ! ! Citer
Davidsic Posté(e) le 20 octobre 2011 Signaler Posté(e) le 20 octobre 2011 Prise en main : http://www.phonearena.com/news/Motorola-DROID-RAZR-hands-on_id23072 (photos et vidéos) Et ici : http://www.techradar.com/news/phone-and-communications/mobile-phones/hands-on-motorola-razr-review-1035117 Citer
-Philippe- Posté(e) le 20 octobre 2011 Auteur Signaler Posté(e) le 20 octobre 2011 me fait également de l'oeil celui-ci Citer
JPeg92 Posté(e) le 20 octobre 2011 Signaler Posté(e) le 20 octobre 2011 Pas mal du tout en effet, mais connaissant Motorola, on est pas prêt de voir tourner ICS dessus... Citer
Saga Posté(e) le 20 octobre 2011 Signaler Posté(e) le 20 octobre 2011 Ils ont quand même été racheté par Google, si ces derniers veulent que cela fonctionne, ils devront ouvrir les vannes ! Mais bon je pense qu'ils vont mettre l'accent sur le Nexus. Mais la news plus haut parle d'un màj début 2012. Au niveau des spécs il n'a rien à envier au Nexus niveau proco en tout cas. Citer
Davidsic Posté(e) le 20 octobre 2011 Signaler Posté(e) le 20 octobre 2011 Si les performances sont du même niveau que mon GS2 je pourrais me laisser tenter. Mais la chose qui m’inquiète le plus est la qualité de l'apn, Motorola est toujours en retrait par rapport aux autres jusque ici Citer
Davidsic Posté(e) le 25 octobre 2011 Signaler Posté(e) le 25 octobre 2011 Prise en main : gsmarena Citer
Caro 7610 Posté(e) le 1 novembre 2011 Signaler Posté(e) le 1 novembre 2011 Une revue photos du Motorola Droid Razr est disponible sur fony.sk (page 1/10) Citer
Davidsic Posté(e) le 3 novembre 2011 Signaler Posté(e) le 3 novembre 2011 Motorola confirms Droid RAZR launch for 11/11/11 at 11.11 am with a cool ad : http://blog.gsmarena.com/motorola-confirms-droid-razr-launch-for-111111-at-11-11-am-with-a-cool-ad-video/ Attention ca coupe ! [media]http://www.youtube.com/watch?v=TgzPBmCGC94&feature=player_embedded Citer
