Fin de SonyEricsson Sync .
Appelé aussi "SonyEricsson Contacts , ce service sera arreté le 29 /12 /2011 ...
It's goodbye to the Sony Ericsson Sync Service.
And hello to the Google Sync Service.
Dear Xxxxx,
Things to do. People to see. Places to go. Thank goodness you’ve got your Sony Ericsson Handset handy to keep you organised. But what if your Sony Ericsson Handset could look after you even more efficiently? How great would that be? Well the good news is that now it can, thanks to Google Sync Services.
Google Sync Services puts you in control of all your contacts and calendars. It’s also a member of Google’s Mobile services family, which includes Gmail, Google Voice Search, Google Maps and YouTube – so you can be confident it works like a dream.
The Sony Ericsson Sync service will close down on 29 December. But there’s no need to worry because you can transfer all your stuff across to Google Sync Services today – either straight from your handset or via the web.
En échange vous êtes invité à rejoindre les services de Google , ou de Plaxo et Unik ( Payant :happy: )
Des options de transfère sont proposés , mais pas les parametres de synchro ..
Dear user,
We are phasing out Sony Ericsson Sync service since it was meant for old generation phones and our aim is to create a more enhanced and integrated smartphone experience for you. As an alternative to Sony Ericsson Sync service, we recommend you to use the Google Sync service for a more integrated experience in line with the favorite range of Google Mobile Services like Google Voice Search, Google Maps and YouTube. Other alternatives are Plaxo and UNYK. If you're already using other sync services, you can of course continue to use them instead.
en savoir + ici : http://www.sonyericsson.com/contactsmigrat...C_gben_nov_2011
Alors Bye Bye SE SyncService , bien pratique pourtant .
C 'est pas une bonne nouvelle . mais c'est un peu la mode de supprimer des services ;il y a déjà eu SE Movies ( et Playnow qui bat de l'aile ) .
Une Question se pose : Google Sync est il compatible avec tous les Mobiles SE ??
OK , Merci ,
C 'est l'une des seules solutions de synchro gatuite , en dehors de certains forfaits proposés par les opérateurs ; chez orange , il y a quelques temps , il faisait payer 0.50 Euros la synchro ! fallait mieux etre en manuelle !
