Just as expected, the iPhone 5s looks the same on the outside (if you don't count the new white with gold/champagne option). It still has the same thin 7.6mm profile and it still weighs merely 112g. However it comes with a number of changes under the hood where pretty much all the work has gone into this time around.
The A7 chipset
The iPhone 5s makes use of a radically re-engineered new chipset, called A7, which is twice as fast in CPU and GPU computations as the iPhone 5.
Based on 64-bit architecture for the first time, the new iPhone 5s is said to be up to 42 times faster than the original iPhone with graphics being up to 53x faster. iOS 7 is now a 64-bit OS, but it's backward compatible with all the currently available 32-bit apps.
The A7 also supports OpenGL ES 3.0, which opens the door to even higher-quality graphics, allowing for real-time computation of effects such as depth of field, blur, full screen vignettes and lens flares.
The processor is accompanied by the M7, a motion co-processor, which measures motion data continuously from the accelerometer, gyroscope, and compass. Along with the new motion sensing API in iOS7 will enable a new generation of sports and fitness apps, which can read and monitor your physical activity much more accurately. The advantage of its presence related directly to the battery life as these apps will only "talk" to the dedicated M7 processor instead of reaching to the power-hungry main CPU.
8MP camera
The new camera has a wider f/2.2 aperture (as opposed to f/2.4) and a 15% larger image sensor, which however is still 8MP. Larger camera sensor provide the benefit of lower noise in low-light conditions and better tonal dynamic range.
There is also a new double LED flash on the iPhone 5s, which Apple has dubbed True Tone, called this way because it allows to achieve more accurate colors tone. It consists of two LEDs, with each having a different color temperature. By analyzing the scene, the iPhone 5s would decide what mix of the LEDs' color temperatures is needed to achieve a naturally lit scene. The dynamic mixing of the LEDs color temperature allows for up to 1000 variations of the light output temperature.
The camera also comes with new image stabilization, albeit digital one. There is also a Burst mode, which would shoot up to 10fos for as long as you keep the on-screen shutter pressed. Best of all, it would analyze the stack of burst photos and would automatically offers the ones it finds to be the sharpest.
The camera will also captures 720p videos at 120fps, allowing it to create slow-mo videos.
The industry-leading Panorama functionality has been improved, too. The Panorama would reach up to 28MP and exposure will adjust automatically as you pan with the phone instead of being fixed on the initial values, which get set at the start of the shooting of each panorama.
Touch ID
As plenty of rumors suggested before, the new iPhone 5s indeed sports a touch sensor embedded into the Home button. It's called Touch ID.
The Touch ID sensor is hidden behind a sapphire crystal lens. Around there is a metallic ring, which would detect the presence of your finger and activate the sensor without you pushing anything.
The concept behind Touch ID is providing enhanced security in the sense that you can set it up to work instead of a passcode lock (which half the iOS users never use, as Apple's Phil Schiller said on stage).
The scanner supports multiple fingerprints and since it recognizes the owner, it can allow you to log on more securely to various services and even make purchases from the iTunes store, for instance, without the need to enter your password.
Misc
The iPhone 5s will offer 10 hours of 3G talk time, up to 250h of standby, up to 40h of music playback.
The new iPhone 5s will be available in black and white fronts as before. For the back however, there is a choice of black with oxidized metal, white with golden metal and white with natural metal color. In essence, only the gold/champagne colored back for the white version is new.
As expected the iPhone 5s will be priced just as the iPhone 5. The iPhone 4S 8GB will be heavily discounted and will be selling for free on a two-year contract. Sadly, the iPhone 5 will be discontinued, obviously to make way for the iPhone 5C.
Both the iPhone 5s and iPhone 5C will launch on September 20 in the US, Australia, Canada, China, France, Germany, Japan, Singapore and the UK. China is in the first wave for the first time.
By December the new iPhones will be available in over 100 countries, including for the first time NTT DoCoMo carrier on Japan.
http://www.gsmarena.com/apple_officially_unveils_the_iphone_5s_learn_everything_inside-news-6765.php
  • Réponses 230
Pour ceux qui on le 5 je voit pas l'interet de changer ... et bon courage pour revendre l'ancien qui n'est pas 4G :whistling:
si si , il sera 4G le1er octobre .... sur Bouygues only :whistling:
Je ne vois rien concernant le NFC pour le 5S ! c'était pourtant quasiment acquis...
PS concernant le forum , j'ai un décalage horaire entre mon post de 20h44 ou je cite Brice à 9h21 PM ???
Modifié par thesurfer17
La keynote que tenait Apple pour l'annonce des nouveaux iPhone vient de s'achever. Peu de surprises au menu, les différentes rumeurs, bien que vagues, au sujet des iPhone 5C et iPhone 5S se sont pour la plupart confirmées. Sortie le 20 septembre.
Après plusieurs mois de rumeurs, Apple vient de dévoiler non pas un mais deux iPhone, comme l'avaient prévus les rumeurs, afin de remplacer son iPhone 5. Voilà un autre point intéressant déjà soulevé ces dernières semaines, l'iPhone 5 s'apprête bien à quitter les rayons en faveur de l'iPhone 5C. Ce dernier reprendra donc l'essentiel de la fiche technique du dernier iPhone alors que l'iPhone 5S portera l'iPhone encore un cran au-dessus. Tous deux bénéficieront néanmoins d'iOS 7, la dernière version du système d'exploitation mobile d'Apple présentée lors de la dernière WWDC en juin dernier.
L'iPhone 5C pour remplacer l'iPhone 5
Au lieu de procéder à l'habituelle baisse de prix appliquée à l'ancienne génération d'iPhone suite à un nouveau lancement, Apple a cette année décidé de proposer l'iPhone 5C auquel il applique un tarif équivalent. Un moyen simple d'assurer les ventes de ce nouveau modèle un peu moins classieux que l'iPhone 5, vêtu de polycarbonate coloré (blanc, rose, jaune, bleu ou vert).
Il en conserve alors l'écran Retina de 4" (1136 x 640 pixels), la puce A6 mais aussi l'appareil photo principal de 8 mégapixels qui a fait le succès du dernier modèle. FaceTime profitera en revanche d'une webcam mieux définie de 1,9 mégapixels. Autre point intéressant, l'iPhone 5C supporterait plus de fréquences 4G/LTE que les autres smartphones du marché. Il devrait donc être compatible avec les réseaux français, contrairement à l'iPhone 5. Il disposera également d'une antenne sur tout son tour, intégrée à sa coque en plastique.
Les précommandes pour l'iPhone 5C seront ouvertes à compter du 13 septembre prochain pour un lancement fixé au 20 septembre. Loin de l'iPhone low-cost tant espéré, Apple affiche déjà un prix de 599 € pour le modèle 16 Go et 699 € pour le modèle 32 Go, nu évidemment. Il sera par ailleurs proposé, en option, avec des coques colorées et percées de sorte laisser sa teinte originelle apparaître pour un design bicolore amusant. Comptez 29 € pour ces dernières.
L'iPhone 5S pour le plein de nouveautés
Apple ne compte évidemment pas affronter la concurrence avec une configuration datée de l'année dernière. Son iPhone 5S comporte lui toutes les évolutions que nous étions en droit d'attendre du nouvel iPhone, néanmoins dissimulées sous un design identique à celui de l'iPhone 5. Il en conserve donc la diagonale de 4" ainsi que la résolution Retina. Seuls de nouveaux coloris Gold et Space Grey, en plus de l'habituel Silver, en feront ainsi évoluer l'aspect esthétique, alors qu'il profitera tout de même de l'interface totalement remaniée d'iOS 7.
Comme chaque année, l'iPhone se voit doté d'un processeur flambant neuf. La puce A6 laisse donc sa place à l'A7, porteuse de nombreuses améliorations. Toujours pas de quad-core au menu, Apple a décidé de jouer sur d'autres tableaux afin d'accroître les performances de son processeur. Il a notamment opté pour une architecture 64 bits. Comme souvent, Apple ne s'est pas éternisé sur l'aspect technique de sa nouvelle puce pour privilégier une approche plus pratique, chiffres à l'appui. Le processeur A7 qui équipe l'iPhone 5S offrirait des performances deux fois supérieures à celles offertes par la puce précédente, si bien en vitesse de calcul (CPU) qu'en traitement graphique (GPU). Plus impressionnant, cela représente une hausse de 40 % pour l'évolution des performances CPU depuis le premier iPhone, et de 56 % pour les performances graphiques.
Cette puce A7 sera également accompagnée d'une nouvelle puce répondant à l'appellation M7, M pour Motion. Associée aux différents capteurs de mouvements intégrées à l'iPhone 5S (accéléromètre, gyroscope, etc), elle est censée ouvrir la voie vers une nouvelle génération d'applications orientées sport et santé afin d'accompagner les utilisateurs au quotidien. Samsung propose toutefois quelque chose de similaire avec S Health.
En revanche, s'il y a un terrain ou Apple a décidé de ne pas suivre ses concurrents, c'est celui de la photo. Là où de nombreux constructeurs optent pour un nombre de pixels plus important à caser sur un capteur ridiculeusement minuscule, la Pomme opte pour un capteur 15 % plus grand que sur le dernier iPhone sans en changer la résolution de 8 mégapixels. On a notamment vu HTC prendre la même direction en début d'année avec son Ultrapixels, dans des proportions toutefois bien plus radicales. Le bénéfice tient dans la taille des pixels, plus grands et capables de capturer une quantité plus importante de lumière. Une bonne chose pour les prises en conditions de luminosité difficiles, lesquelles devraient également profiter de la plus grande ouverture permise par l'objectif de l'appareil. Toujours composé de 5 lentilles, il passe d'une ouverture f/2.4 à une ouverture plus lumineuse f/2.2. Notons que l'iPhone 5S dispose également d'un Flash dual-LED, au fonctionnement un peu particulier.
Que seraient toutes ces évolutions techniques sans une partie software qui tient la route ? Outre améliorer son algorythme pour le traitement des images, Apple a également doté l'appareil photo de son iPhone 5S de nouvelles fonctionnalités. La balance des blancs et l'exposition s'ajusteront constamment dans le viseur afin d'éviter toute restitution de couleur malheureuse. Autre allié dans cette restitution plus juste, le flash dual-LED s'adapte à l'environnement avec des tons plus ou moins chauds selon la scène visée. L'iPhone 5S intègre également un mode de sélection du meilleur cliché, ainsi qu'un mode rafale capable de capturer 10 images par seconde afin de ne jamais louper une prise. Apple a même pensé à doter la galerie d'un Camera Roll pour s'y retrouver plus facilement. Un algorythme sélectionne les clichés les plus réussis pour les afficher, alors que les autres resteront accesssibles manuellement. Le mode vidéo intègre lui un mode Slow Motion reposant sur une vitesse d'enregistrement de 120 images par secondes.
Dernière nouveauté et non des moindres, Apple a bien intégré un capteur biométrique à son nouvel iPhone. Répondant au nom de Touch ID, il se cache dans le nouveau bouton Home conçu spécialement pour lui. Débarrassé de l'habituel carré en son centre, il se dote désormais de sapphyre de cristal pour une meilleure résistance au temps ainsi que d'un anneau métallique. Le capteur sera capable de lire les empreintes digitales de son utilisateur peu importe leur orientation, afin notamment de déverrouiller le terminal en y posant simplement son doigt. Cette mesure de sécurité sera sans doute également très appréciée sur iTunes, où les paiements s'effectueront de la même manière, sans nécessiter la saisie d'informations quelles qu'elles soient. Un gain de temps aussi, donc.
Aucune précommande pour l'iPhone 5S n'a été évoqué. Il sera néanmoins disponible, comme l'iPhone 5C, à compter du 20 septembre en trois modèles 16, 32 et 64 Go attendus aux prix respectifs de 699, 799 et 899 € nus. De nouvelles coques de protection en cuir seront également disponibles au prix de 39 €. L'iPhone 4S survivra à l'arrivée des nouveaux iPhones et sera proposé gratuitement après subventions.
Oui le 5 est bien 4G, je l'utilise tous les jours.
Par contre effectivement, très peu d'intérêt à changer. Je ne suis pas convaincu par la puissance supplémentaire alors que le 5 est déjà fluide.
L'appareil photo semble bien, mais ne justifie pas de racheter un téléphone surtout à ce prix. Autant prendre le QX10 de chez Sony et le foutre dessus.
Et pour la partie Touch ID, je suis déçu qu'il n'est pas prévu de partenariat avec des enseignes pour pouvoir payer de manière sécurisée. Encore aurait il fallu qu'ils intègrent le NFC....
Bref, mon 5 va faire l'affaire et peut être serais je tenter par le Nexus 5, surtout si ils gardent les prix du 4 à sa sortie.
Je vous annonce en exclusivité la prochaine évolution de l'IPhone 5S : dos doré (je préfererais dire Champagne, mais c'est interdit) avec le modele noir :good:
Cela pourrait etre assez réussi comme effet. Je viens de l'inventer et je m'étonne qu'Apple n'y ait pas pensé...
Que l'iPhone 5S soit plus performant que l'iPhone 5 n'est pas réellement une surprise. Apple a annoncé son dernier-né comme deux fois plus puissant que l'ancien modèle, des mesures confirmées aujourd'hui par un premier benchmark.
Autant l'iPhone 5C en a déçu plus d'un, autant l'iPhone 5S laissait entrevoir un certain nombre d'évolutions intéressantes, et nottament en termes de performances. Apple a une nouvelle fois décidé de ne pas se laisser hâppé par cette tendance à la multiplication des coeurs au profit d'une optimisation hardware/software sans pareil qui fait son petit effet. Il annonçait ainsi des performances quasiment doublées avec sa nouvelle puce dual-core A7, en comparaison à l'A6 qui équipait son iPhone 5, ou l'iPhone 5C dorénavant.
Evidemment, le discours d'Apple ne vaut pas plus que celui de Samsung, LG ou n'importe quel autre constructeur placé sous la lumière des médias. Mieux vaut alors en passer par les habituels benchmarks pour se faire une réelle idée du chemin parcouru par la Pomme, qui a visiblement roulé aussi loin qu'annoncé à en croire le GFXBench. L'outil de mesure de performances indique une moyenne de 56 images par seconde au test Egypt HD, écran éteint, pour l'iPhone 5S contre 29,8 pour l'ancien modèle, soit le double à peu de chose près. Le même test, écran allumé, le fait néanmoins chuter à une moyenne de 53 images par seconde contre 41,1 pour l'iPhone 5, une hausse toujours significative qui le place au niveau de ses concurrents équipés du Snapdragon 800 de Qualcomm, et un poil en dessous du NVIDIA Shield et son Tegra 4.
