-Philippe- Posté(e) le 1 octobre 2015 Signaler Posté(e) le 1 octobre 2015 LG officially announced the high-end V10 smartphone with secondary display and a duo of front-facing cameras. The Korean manufacturers latest flagship phablet will hit the shelves in Korea this month in five different color schemes - Space Black, Luxe White, Modern Beige, Ocean Blue, and Opal Blue. Just as the leaks suggested, the defining feature of the LG V10 is an secondary display located above the handsets 5.7 QHD unit. The 2.1 additional screen has a resolution of 1040 x 160 pixels and can display app shortcuts and other relevant information in always on mode. In addition to ints rather unique display setup, LG V10 packs a duo of 5MP front-facing cameras. One of the units has a standard angle lens, while the other on offers a wide angle solution for easy group selfies. LG V10 features a body with 316L stainless steel frame and display covered by dual-layer Gorilla Glass 4.The removable back cover of the device is made of silicon-like material dubbed Dura Skin. Specs-wise, LG V10 packs Qualcomm Snapdragon 808 SoC, 4GB of RAM, and 64GB of expandable memory via microSD card slot. A fingerprint sensor that's embedded in the power button, Hi-Fi DAC, full connectivity suite, and 3,000mAh removable battery are also on board. The handset boots Android 5.1.1 Lollipop. The main camera of the smartphone is the same 16MP unit with f/1.8 lens and laser autofocus found in LG G4. This time around, LG has brought manual controls even to the smartphones camcorder. Users can even adjust the sound volume of the clips they record. Physical measures of the LG V10 are 159.6 x 79.3 x 8.6mm. Its weight tips the scale at 192 grams. LG V10 will also launch in the United States, China, as well as other markets in Asia, Latin America, and the Middle East. Specific launch details about each market will be announced in the near future. http://www.gsmarena.com/lg_v10_goes_official_with_secondary_display_and_a_duo_of_frontfacing_cameras-news-14251.php Citer
Brice Posté(e) le 1 octobre 2015 Signaler Posté(e) le 1 octobre 2015 Très bonne machine mais énorme et encore plus lourd que le i6S+ pour ceux qui aime pas les grand et lourd modèle c'est mort Toute façon pour l'instant c'est pour la Corée , après peut être les états Unis et éventuellement l'Europe Plus large , plus long , plus épais qu'un Note 4 pour vous donner une idée Citer
-Philippe- Posté(e) le 1 octobre 2015 Auteur Signaler Posté(e) le 1 octobre 2015 Comme prévu, LG a présenté le premier représentant dune nouvelle gamme de smartphones : le V10. Cette grande phablette, qui viendra chatouiller les iPhone 6S Plus, Galaxy S6 Edge+ et Galaxy Note 5, tente dapporter une touche doriginalité avec son second écran. Si Samsung a ses écrans Edge, LG aura son écran secondaire. Aperçu à de nombreuses reprises ces dernières semaines, le LG V10, porte-étendard désormais officiel de la marque coréenne pour cette fin dannée, ne jouera pas loriginalité sur la courbe de son écran, mais bien sur lajout de ce petit afficheur additionnel au-dessus de la dalle principale. Une idée presque nouvelle, même si elle ressemble pour beaucoup à celle que Samsung a tenté doffrir avec le Galaxy Note Edge lannée dernière dont lapproche était clairement bonne, mais pas assez développée par Samsung pour en faire un «killer app». Espérons donc que LG aura, lui, poussé le concept pour faire de ce second écran une vraie innovation disruptive dans la prise en main (et non un gadget inutile). LG V10 Mais ce nest pas sa seule curiosité, comme vous le verrez tout au long de cet article. Mais commençons par le commencement. Présenté comme attendu lors dune conférence de presse à Séoul, le LG V10 est clairement un modèle haut de gamme, dans la proposition comme dans léquipement. Le châssis, tout dabord, est réalisé en acier inoxydable et en polycarbonate pour la coque arrière. Il mesure 8,6 mm dépaisseur et pèse 192 grammes. Le choix des matériaux aurait été dicté non seulement pour la prise en main, mais aussi pour la résistance aux chocs. Au dos, vous retrouvez, sous le capteur photo le triptyque habituel de boutons : deux pour le volume et un pour la mise en marche. Ce dernier est désormais affublé dun lecteur dempreinte digitale dont la forme nous rappelle étrangement... le Nexus 5X ! Un écran secondaire bien pratique À lavant, nous retrouvons les deux écrans tactiles qui ont fait sa renommée dans le flot incessant des rumeurs. Le premier est un écran Quantum IPS Quad HD de 5,7 pouces (résolution de 513 pixels par pouce). Le second est également Quantum IPS, mais mesure 2,1 pouces et se présente comme une bande qui surligne lécran principal sur pratiquement toute la largeur. Cet écran, dont la résolution est également de 513 pixels par pouce, affiche aussi bien des raccourcis, des commandes déportées (pour le multimédia), des raccourcis, des notifications (habituellement dévolues au centre de notification dAndroid), des alertes, des messages ou tout autre élément. Lensemble est non seulement modifiable, mais surtout contextuel et indépendant : plus besoin de désactiver le mode plein écran pour prendre un appel ou cacher une notification. Des fonctions que nous avions aimé sur le Galaxy Note Edge lors de nos tests lannée dernière et qui devraient être encore plus pratiques ici. LG V10 Double selfie ? Cest également à lavant que nous retrouvons la seconde originalité du V10 : un duo de capteur visio. Comme le Vibe S1 de Lenovo, le LG V10 propose deux webcams à lavant. Mais contrairement au smartphone chinois, qui se sert du second capteur pour aider le premier à faire la mise au point, le V10 utilise ses deux capteurs pour créer des photos grand-angles (120 degrés). Les deux composants disposent de 5 millions de pixels et leurs prises de vue sont combinées pour créer une seule et même photo. Notez quils peuvent aussi agir indépendamment et en synergie avec le capteur principal pour créer des séquences avec trois points de vue simultanément. Évidemment, pour animer trois capteurs photo et deux écrans de 512 points par pouces, il faut une plate-forme véloce. LG en a choisi une quil maitrise plutôt bien maintenant, puisquil lutilise déjà avec le G4 et le Nexus 5X : le Snapdragon 808 de Qualcomm, version hexa-core du Snapdragon 810 disposant seulement de deux coeurs Cortex-A57. À cela sajoutent 4 Go de mémoire vive (format LPDDR3), soit plus que les deux mobiles précédemment cités, et 64 Go de stockage extensible par microSDXC. Une batterie de 3000 mAh, amovible et compatible Quick Charge 2.0, complète le tout. Il est évidemment compatible WiFi ac, LTE catégorie 6, Bluetooth 4.1, NFC et GPS. LG V10 >Un coeur de G4 amélioré Côté multimédia, deux détails à signaler en plus du double capteur à lavant : le capteur principal et le chipset audio. Le premier est le modèle 16 mégapixels qui équipe actuellement le G4. Aucune surprise donc à ce quil soit compatible Ultra HD (et même 4K, pour ceux qui savent faire la différence). Comme dans le G4, le capteur est accompagné dun objectif stabilisé ouvrant à f/1.8 (une excellente luminosité donc), dun autofocus laser, dun double flash LED et dune application photo offrant tous les réglages attendus par les photographes amateurs. Le chipset audio est un composant développé par ESS compatible avec les échantillonnages 32 bit. Le son devrait donc être de bonne qualité. Proposé en cinq coloris (noir, blanc, beige, bleu clair et violet), le smartphone est destiné à une commercialisation internationale. Il sortira ce mois-ci en Corée avant datteindre les côtes américaines et chinoises dans un deuxième temps. LAsie, lAmérique latine et le Moyen-Orient sont également concernés. Pas de mot pour lEurope, curieusement. Comme toujours, le prix des nouveautés chez LG nest pas annoncé. Il faudra donc attendre une confirmation en France pour découvrir son prix en euro. Ce que nous espérons vivement. http://www.lesmobiles.com/actualite/19498-lg-presente-officiellement-le-v10-son-smartphone-double-ecran.html Citer
Davidsic Posté(e) le 1 octobre 2015 Signaler Posté(e) le 1 octobre 2015 Très bonne machine mais énorme et encore plus lourd que le i6S+ pour ceux qui aime pas les grand et lourd modèle c'est mort +1 Par contre ça semble prometteur pour les futur haut de gamme : finition plus premium, lecteur d'empreinte, un peu de d'innovation avec le petit écran... Citer
Marko Posté(e) le 1 octobre 2015 Signaler Posté(e) le 1 octobre 2015 Merci pour la vidéo David, effectivement il est plus beau que le G4 Le deuxième écran pour les notification est très sympa Dans le micro SD slot on voit une carte 200 Go ? Citer
Davidsic Posté(e) le 1 octobre 2015 Signaler Posté(e) le 1 octobre 2015 ça peut recevoir jusqu’à 200To oui mais bon...ça ne doit pas être pour rien une SD de cette capacité. On l'oublierait presque mais c'est le remplaçant du G Pro 2 (enfin je pense du moins) Prise en mains ici http://www.phonearena.com/news/LG-V10-hands-on_id74271 et ici http://www.gsmarena.com/lg_v10_watch_urbane_2nd_ed_handson-review-1315p2.php Citer
-Philippe- Posté(e) le 1 octobre 2015 Auteur Signaler Posté(e) le 1 octobre 2015 pas si énorme enfin de compte. Citer
Davidsic Posté(e) le 1 octobre 2015 Signaler Posté(e) le 1 octobre 2015 En tout cas trop large et un peu lourd quand même pour moi. Puisque LG a insisté sur la résistance du V10... Citer
Steph Posté(e) le 1 octobre 2015 Signaler Posté(e) le 1 octobre 2015 Sympa ce mobile mais j'ai peur du prix. Citer
-Philippe- Posté(e) le 1 octobre 2015 Auteur Signaler Posté(e) le 1 octobre 2015 pas si énorme : The Korea Herald nous informe aussi de son prix, qui serait de 799 700 wons, ce qui représente un peu moins de 610 euros. Il y a peu de chances que LG applique exactement ce prix sur le marché européen, mais ce chiffre a au moins le mérite de nous donner une estimation du tarif que nous pourrions hériter. Citer
Steph Posté(e) le 1 octobre 2015 Signaler Posté(e) le 1 octobre 2015 Il sera plus chere c'est sûr. Citer
Brice Posté(e) le 1 octobre 2015 Signaler Posté(e) le 1 octobre 2015 Oui en france faut pas rêver il seras plus chère mais bon suffit d'attendre un peu et il baissera Citer
Steph Posté(e) le 1 octobre 2015 Signaler Posté(e) le 1 octobre 2015 C'est clair que niveau drop test, n'importe quel autre mobile aurait eu l'ecran d'explosé dans ces conditions. Bravo LG Citer
Marko Posté(e) le 2 octobre 2015 Signaler Posté(e) le 2 octobre 2015 Effectivement, très résistant ce V10 Citer
-Philippe- Posté(e) le 2 octobre 2015 Auteur Signaler Posté(e) le 2 octobre 2015 Très beau design !! http://www.gsmarena.com/lg_v10-7606.php Citer
