-Philippe- Posté(e) le 1 mai 2014 Signaler Share Posté(e) le 1 mai 2014 IntroductionWith the new season well under way, the LG G2 mini is trying to have the last word in the compact class just like the original did last year at the high end. With the same design as the flagship (slim bezel, rear buttons and such) and the biggest screen among the minis, LG's compact smartphone is putting its best foot forward. But then, just like the flagship, the LG G2 mini is going after a certain competitor and not exactly keeping it a secret. The screen resolution, the chipset, the imaging skill are the same as the Galaxy S4 mini's. In other words, if anyone was hoping for something along the lines of the Sony Xperia Z1 Compact, they'll be disappointed. LG G2 mini official photos No, the G2 mini isn't a compact powerhouse. It's a well-rounded package still, and one that even does a couple of things better than the flagship, in hope to find a place in the crowded place where minis have to deal with ex-flagships and aggressively priced mid-rangers. Key featuresQuad-band GSM/GPRS/EDGE support Quad-band 3G with HSPA; Optional Penta-band LTE cat4 4.7" 16M-color qHD (960 x 540) IPS LCD, Gorilla Glass 2 display protection Android OS v4.4.2 KitKat; LG Optimus UI Quad-core 1.2 GHz Cortex-A7 CPU, 1 GB RAM, Adreno 305 GPU, Qualcomm Snapdragon 400 chipset 8 MP autofocus camera with LED flash, geotagging, smart shutter and VR panoramas 1080p video recording @ 30fps with stereo sound; HDR mode 1.3 MP front-facing camera, 720p video recording 8GB of built-in storage microUSB port, USB host support, USB on-the-go, SlimPort TV-out Bluetooth v4.0 NFC (in the LTE version only) Wi-Fi a/b/g/n, Wi-Fi Direct and DLNA GPS with A-GPS, GLONASS Standard 3.5 mm audio jack Stereo FM radio with RDS Voice commands Multi-tasking with mini-apps and optional transparency (QSlide) Knock Code unlocks the phone with a screen tap combination Accelerometer and proximity sensor Active noise cancellation with dedicated mic User-replaceable 2440mAh Li-Ion battery IR emitter for remote control of home appliances http://www.gsmarena.com/lg_g2_mini-review-1070.php Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Higgins Posté(e) le 1 mai 2014 Signaler Share Posté(e) le 1 mai 2014 Un test du G2 Mini sur http://www.phonandroid.com/test-lg-g2-mini.html Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
-Philippe- Posté(e) le 6 juin 2014 Auteur Signaler Share Posté(e) le 6 juin 2014 Le G2 a marqué le grand retour de LG dans l'univers de la téléphonie. Il tente aujourd'hui de rebondir sur son succès et dégaine le G2 Mini. Simple opération marketing ou véritable déclinaison du flagship ? Réponse à la fin de notre test flash. LG a été le dernier grand constructeur à se prêter au jeu délicat de la miniaturisation. Sans doute attendait-il un véritable succès commercial sur lequel rebondir. Objectif atteint avec le G2 lancé à l'été 2013. Six mois plus tard, un G2 Mini voyait naturellement le jour. Le constructeur espère ainsi séduire les consommateurs bloqués par les dimensions de son dernier flagship. Le G2 Mini est logiquement plus compact que son modèle, mais ce n'est pas tout. LG en a également profité pour éliminer un autre frein potentiel : le prix, fixé cette fois à 299 €. Pour ce faire, il n'a pas hésité à remplacer plusieurs composants par d'autres, plus économiques. En voici la liste : Android 4.4 KitKat + surcouche LG écran IPS qHD (960 x 540 pixels) de 4,7 pouces processeur quad-core Snapdragon 1,2 GHz GPU Adreno 305 1 Go de RAM 8 Go de mémoire interne + microSD appareil photo 8 mégapixels avec OIS webcam 1,3 mégapixels connectivités 4G, NFC, Bluetooth 4.0, WiFi (802.11 b/g/n), A-GPS transmetteur infrarouge batterie amovible de 2440 mAh dimensions : 129,6 x 66,0 x 9,8mm poids : 121g Un design connu, ou presque Contre toute attente, le G2 Mini réserve quelques surprises à l'extérieur. Il reprend évidemment les lignes et l'ergonomie du G2, mais s'en distingue à plusieurs niveaux. L'avant est toujours majoritairement occupé par l'écran et dépourvu de boutons, tout comme les tranches. Celles-ci accueillent port microUSB/haut-parleurs en bas et jack/transmetteur IR en haut. Les boutons de mise en marche et de volume sont donc à nouveau à l'arrière, sous l'appareil photo et son flash, mais diffèrent par leur relief plus important. http://www.lesmobiles.com/actualite/14345-test-du-lg-g2-mini-ce-n-est-ni-un-mini-ni-un-g2.html Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dood03 Posté(e) le 10 novembre 2014 Signaler Share Posté(e) le 10 novembre 2014 Bonjour, j'ai besoin d'un nouveau téléphone et j'hésite entre le lg g2 mini (car il a le 4g) et le wik getaway, son seul défaut selon moi est l'absence du 4g mais j'adore son design. J'aurais bien voulu le Highway 4g mais il ne fait que 16gb et est un autre budget. Donc si vous pouviez me dire lequel vaut plus le coup entre le g2 mini et le getaway ou si vous connaissez d'autres avec le design du getaway et la 4g aux alentours de 200e! Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Higgins Posté(e) le 10 novembre 2014 Signaler Share Posté(e) le 10 novembre 2014 J'ai répondu sur ton autre post http://www.planete-smartphones.fr/forum/index.php?/topic/4252-LG-G2-mini-ou-Wiko-Getaway? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
CC. Rider Posté(e) le 27 janvier 2016 Signaler Share Posté(e) le 27 janvier 2016 Un vrai chameau ce petit G2 Mini, c'est pas rare que je fasse 5h00 d'écran. C'est vraiment une bonne surprise surtout pour le prix qu'il m'a coûté. Du coup je me suis pas encore beaucoup servi de mon 5S flambant neuf. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
