-Philippe- Posté(e) le 10 juin 2014 Signaler Share Posté(e) le 10 juin 2014 Samsung Galaxy S5 mini has been in our rumor mill for quite a while, but today we are finally getting to see the real deal. We can got high-res live pictures of the S5 mini plus a comparison shot with its bigger Galaxy S5 sibling. Samsung Galaxy S5 mini in black and white • Galaxy S5 mini next to a Galaxy S5 As you can see the Galaxy S5 mini utilizes the same design as the flagship, it even keeps the same dotted plastic back. Even the heart-rate monitor is on the same spot. The picture source claims the device is still IP67-certified for water and dust protection even though there is no protective lid on the microUSB slot as is the case with Galaxy S5 and Galaxy S5 Active. Samsung Galaxy S5 mini We can also confirm S5 mini specs - it features a 4.5" Super AMOLED display of 720p resolution and runs on Exynos 3 Quad chipset with a quad-core Cortex-A7 CPU @ 1.4GHz, Mali-400 MP4 GPU and 1.5GB of RAM. The rest of the Samsung Galaxy S5 mini specs highlight include Gorilla Glass 3 screen protection, 8MP rear camera, 2.1MP front snapper, 16GB expandable storage, fingerprint scanner and heart-rate monitor. The connectivity options are pretty much the same as the Galaxy S5 - LTE, 3G, Wi-Fi, Bluetooth 4.0, NFC, IR blaster, GPS with GLONASS. Samsung Galaxy S5 mini is running on Android 4.4.2 KitKat with the latest available TouchWiz UX that premiered on the Galaxy S5. You will be getting Ultra Power Saving Mode, Kids Mode, Private Mode, KNOX, among others. http://www.gsmarena.com/samsung_galaxy_s5_mini_leaks_in_hires_pics_specs_in_tow-news-8750.php Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Brice Posté(e) le 10 juin 2014 Signaler Share Posté(e) le 10 juin 2014 Tout a fait logique de sortir des versions mini pour les constructeurs Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
-Philippe- Posté(e) le 11 juin 2014 Auteur Signaler Share Posté(e) le 11 juin 2014 Alors que la variante Active du Galaxy S5 a déjà été officialisée aux Etats-Unis, la variante « Mini » se fait toujours attendre. Non pas sans les habituelles fuites, évidemment. De nouvelles photos circulent sur la toile. Elles sont même accompagnées de captures d'écrans réalisées sur AnTuTu. Comme son prédécesseur, le Galaxy S5 sera très certainement décliné en une variante « Mini » adressée aux consommateurs freinés par les dimensions du flagship. Peu de surprises sont attendues sur le plan esthétique, si ce n'est pour des changements occasionnés par l'absence de certains composants. Les premières photos que nous relayions la semaine dernière était cependant rassurantes en ce sens. De nouvelles, à nouveau diffusées par SamMobile, soulèvent tout de même une interrogation importante. Une copie en apparence conforme, à un détail près Aucune perte importante à déplorer. Le cardiofréquencemètre à l'arrière est toujours présent, tout comme le joint étanche à l'intérieur du capot. En revanche, la trappe protégeant le port microUSB a disparu, signe que le Galaxy S5 Mini ne sera peut-être pas aussi résistant à l'eau que son modèle. Pour rappel, ce dernier est certifié IP67 et supporte une immersion jusqu'à 1 mètre de profondeur pour une durée maximale de 30 minutes. L'auteur des clichés affirme tout de même que le nouveau modèle est, lui aussi, certifié IP67. Samsung Galaxy S5 Mini Une fiche technique bien inférieure Il a également ajouté plusieurs photos comparatives avec le modèle original, en plus de captures d'écran réalisées sur AnTuTu. Nous y découvrons le score obtenu par le Galaxy S5 Mini, mais aussi la plateforme technique qui se cache derrière. Les rumeurs précédentes se confirment puisque l'on y trouve un nouveau CPU Exynos 3470 composé de quatre coeurs Cortex-A7 cadencés à 1,4 GHz. Celui-ci a été complété par un GPU Mali-400 MP4, 1,5 Go de RAM et 16 Go de mémoire interne extensible. Deux appareils photo sont également présents : 8 et 2,1 mégapixels. L'affichage repose, quant à lui, sur une dalle HD 720p de 4,5 pouces. L'ensemble tourne évidemment sous Android 4.4.2 KitKat. Samsung Galaxy S5 Mini : AnTuTu Le Galaxy S5 Mini sera donc plus petit que le Galaxy S5, mais aussi moins bien équipé. Son score AnTuTu s'en ressent : 18 405 points. C'est bien inférieur au score du Galaxy S5 (supérieur à 30 000 points). Cela étant, le One Mini 2 de HTC n'a pas beaucoup mieux à offrir. http://www.lesmobiles.com/actualite/14383-samsung-galaxy-s5-mini-de-nouvelles-photos-circulent-sur-la-toile-accompagnees-de-screenshots-d-antutu.html Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Marko Posté(e) le 1 juillet 2014 Signaler Share Posté(e) le 1 juillet 2014 Samsung sort son Galaxy S5 Mini, plus compact et plus abordable Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
-Philippe- Posté(e) le 1 juillet 2014 Auteur Signaler Share Posté(e) le 1 juillet 2014 Without much fanfare Samsung unveiled the Galaxy S5 mini. It grew slightly compared to its predecessor with a 4.5" screen, keeping within the reasonable limits of "mini". The specs aren't particularly high-end though it retains the trademark features of the big Galaxy S5. The Samsung Galaxy S5 mini is built around a 4.5" Super AMOLED screen of 720p resolution. It measures 131.1 x 64.8 x 9.1 and weighs 120g, compared to 124.6 x 61.3 x 8.9 mm and 107g of the Galaxy S4 mini. The good news is that the pixel density went from 256ppi to 326ppi. The body is IP67 certified meaning it is completely dust tight and can be submerged under up to a meter of water for half an hour. Interestingly there's no flap covering the microUSB 2.0 port on the bottom, Samsung has managed to make it water resistant with some sort of special coating. The back is perforated leather and features a heart rate monitor, while the hardware Home key on the front doubles as a fingerprint reader. Samsung Galaxy S5 mini The processing power hasn’t gone up significantly - the Galaxy S5 mini packs four Cortex-A7 cores @ 1.4GHz, while RAM remains at 1.5GB. The internal storage was doubled to 16GB (there's a microSD card slot if that's not enough). The Galaxy S5 mini will come out with Android 4.4 KitKat and feature S Health, Private mode, Kids mode and Ultra Power Saving mode. The battery capacity went up a bit to 2,100mAh. The connectivity was bumped up to 150Mbps LTE and keeps the IR blaster on top. The camera department remains unchanged at 8MP stills and 1080p @ 30fps video. The camera features the Shot & more and Virtual Tour modes from the big Galaxy S5 as well as the S Studio editor. Four color options for the Galaxy S5 mini The Samsung Galaxy S5 mini will begin its rollout in Russia early this month in four color options: Charcoal Black, Shimmery White, Electric Blue and Copper Gold. Pricing hasn’t been announced yet, but there's a dual-SIM version inbound. http://www.gsmarena.com/samsung_galaxy_s5_mini_official_with_45_screen_all_s5_sensors-news-8911.php Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
-Philippe- Posté(e) le 1 juillet 2014 Auteur Signaler Share Posté(e) le 1 juillet 2014 Samsung n’en finit plus de lancer des smartphones. Après avoir renouvelé l’ensemble de son offre entrée de gamme hier, le groupe coréen officialise le Galaxy S5 Mini, variation petit format de son flagship annuel qui, comme toujours, accuse aussi une baisse de sa fiche technique vis-à-vis du modèle original. Cela n’arrête plus. Après l’armada de nouveautés annoncées officiellement hier sur le segment entrée de gamme, voici encore un autre smartphone Galaxy annoncé. Et pas des moindres puisqu’il s’agit du Galaxy S5 Mini, déjà aperçu sur AnTuTu, GFXBench et via quelques photos parues il y a un mois. Le voici donc tout officiel, tel que les différentes rumeurs (notamment les plus récentes) le décrivaient. À commencer par un châssis en tout point comparable à celui du Galaxy S5, mais en plus petit, bien évidemment. Cette version Mini en reprend les lignes et la coque arrière amovible, en polycarbonate et motif en pointillés. Comme cela était annoncé dans une rumeur précédente, les deux capteurs biométriques (tension artérielle et empreinte digitale) sont conservés. C’est également le cas de la certification IP67, protégeant le mobile des infiltrations de poussières et d’eau. Le tout pèserait 120 grammes pour une épaisseur de 9,1 mm. Le Galaxy S5 Mini est plus imposant que le Galaxy S4. Un chipset Exynos, même dans sa version LTE L’écran du Galaxy S5 Mini, Super Amoled, est de 4,5 pouces (et non 4,8 pouces comme cela a pu être écrit précédemment). Sa définition est 720p, soit une belle amélioration vis-à-vis du S4 Mini. Le chipset est un modèle quad-core cadencé à 1,4 GHz. Le GPU n’a pas été officiellement dévoilé pour laisser le doute sur l’origine du composant. Selon les différents benchmarks, il s’agirait d’un Exynos 3470, doté de quatre coeurs Cortex-A7 et d’un GPU ARM Mali 400. Selon le site allemand AllAboutSamsung.de, il équiperait aussi bien la version 3G (internationale) que la version 4G (qui serait réservée au marché européen). Pour accompagner ce chipset, 1,5 Go de mémoire vive, 16 Go de stockage interne (extensible par microSD), une batterie 2100 mAh, un capteur photo 8 mégapixels, un capteur visio 2,1 mégapixels, une connectivité complète (HSDPA 42 Mb/s et/ou 4G 150 Mb/s, infrarouges, GPS, Bluetooth 4.0 LE, WiFi n et NFC dans la version LTE). Le tout tourne avec Android KitKat 4.4 et intègre certaines fonctionnalités apparues avec la version de Touchwiz du Galaxy S5 : l’Ultra Power Saving Mode, Mode Enfants. S Health est évidemment de la partie. Un "mini" S5 dans tous les sens, mais pas forcément dans le prix Le S5 Mini est certes meilleur que le S4 Mini, mais cette fiche technique n’est pas étourdissante non plus, Samsung se gardant bien de proposer un mobile performant avec un écran de moins de 5 pouces pour éviter de faire de l’ombre à son flagship. Disponible à partir du début du mois en Russie, puis dans d’autres pays à l’international, le Galaxy S5 Mini sera proposé en quatre coloris dès son lancement : blanc, noir, doré et le beau bleu électrique de la gamme Galaxy. Le prix de vente atteindrait les 479 euros hors subvention, soit plus cher encore que le Galaxy S4 Mini (449 euros au lancement). Espérons que le S5 Mini ne sera pas autant boudé que son prédécesseur... http://www.lesmobiles.com/actualite/14609-samsung-galaxy-s5-mini-officialise-toujours-pas-le-mini-flagship-espere.html Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
-Philippe- Posté(e) le 27 juillet 2014 Auteur Signaler Share Posté(e) le 27 juillet 2014 Dispo chez Médiamarkt Meyrin, prix 519.- CHF !! Pris dans les mains, exactement les mêmes finitions que le grand frère. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Davidsic Posté(e) le 9 août 2014 Signaler Share Posté(e) le 9 août 2014 -> http://blog.gsmarena.com/samsung-galaxy-s5-mini-hands/ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Davidsic Posté(e) le 17 août 2014 Signaler Share Posté(e) le 17 août 2014 Review -> http://www.gsmarena.com/samsung_galaxy_s5_mini-review-1116.php Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
denardou Posté(e) le 9 septembre 2014 Signaler Share Posté(e) le 9 septembre 2014 Comment peuvent t im vendre un s 5 mini plus cher qu un k zoom ... En conception le k coute quand même beaucoup plus cher Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
-Philippe- Posté(e) le 17 septembre 2014 Auteur Signaler Share Posté(e) le 17 septembre 2014 Le S5 a aussi le turbo boost Wifi + 4G ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Davidsic Posté(e) le 17 septembre 2014 Signaler Share Posté(e) le 17 septembre 2014 Non Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
-Philippe- Posté(e) le 1 octobre 2014 Auteur Signaler Share Posté(e) le 1 octobre 2014 Tradition oblige, Samsung a décliné son smartphone phare du début d’année en plusieurs modèles pour des segments précis. Le Galaxy S5 Mini se veut donc être une réponse économique à l’envie de certains de profiter de tout ce qu’apporte le S5 sans avoir à débourser plus de 600 euros hors subvention. Comme le S4 Mini, mais aussi le G3S de LG ou le One Mini 2 de HTC, le Galaxy S5 Mini est une déclinaison appauvrie d’un modèle « porte-étendard ». Il en reprend le design, l’interface utilisateur et une partie des fonctionnalités, mais cache derrière ces beaux atours une diminution drastique des composants et des fiches techniques. Nous déplorons souvent que Sony soit le seul à offrir à sa déclinaison « compact » une fiche technique digne du très bon haut de gamme. Cette année encore, le Z3 Compact devrait être excellent (sauf sur son prix...). Seulement, comme la concurrence est un peu plus dure ces derniers temps, surtout sur le milieu de gamme, les fabricants hésitent à tout enlever. La visée laser du G3 est donc restée dans le G3S. La belle coque en aluminium du One (M8) équipe le One Mini 2. Et le Galaxy S5 Mini n’est pas totalement démuni non plus, comme vous allez pouvoir le constater tout au long de ce test. Une fiche technique meilleure que celle du S4 Mini Soyons clairs, le S5 Mini ne remplacera pas le S5 traditionnel. Et ce n’est pas l’objectif. Il se veut clairement être le représentant de Samsung sur la tranche des smartphones de 4,5 pouces et moins. Cependant, Samsung n’a pas été aussi chiche que d’habitude. Comparé au S4 Mini, ce S5 Mini est une meilleure affaire, même si nous pourrions trouver cela un peu trop cher. Faisons ensemble le tour du propriétaire : Ecran Super Amoled 720p de 4,5 pouces, pour une résolution de 326 points par pouce Chipset Exynos 3 Quad 3470 formé d’un quad-core Cortex-A7 cadencé à 1,4 GHz GPU ARM Mali 400MP4 cadencé à 450 MHz 1,5 Go de mémoire vive 16 Go de stockage interne (extensible par microSD) Batterie 2100 mAh Compatible LTE catégorie 4, WiFi dual band, NFC, Bluetooth 4.0, GPS Glonass Lecteur d’empreinte digitale certifié PayPal et cardiofréquencemètre Capteur photo principal 8 mégapixels, enregistrement vidéo Full HD Webcam 2,1 mégapixels Android KitKat 4.4.2 avec surcouche Touchwiz Étanchéité IP67 Poids 120 grammes Épaisseur : 9,1 mm Le joint d'étanchéité se voit ici parfaitement Plusieurs remarques dans cette fiche technique. D’abord, l’arrivée de la HD dans un smartphone petit format chez Samsung, cela se fête. Nous avons enfin une image précise qui fait honneur à la dalle Super Amoled. Ensuite, l’intégration de l’Exynos 3470, réponse certaine au Snapdragon 400 de Qualcomm. Ce chipset, sorti cette année, n’a été intégré, pour le moment, que dans le Galaxy S5 Mini. Compatible LTE, il équipera certainement une partie des modèles internationaux économiques de Samsung sur 2015. Ses performances sont, comme nous le verrons, légèrement au-dessus de la concurrence de Qualcomm. Enfin, dernière bonne nouvelle, quelques caractéristiques du S5 sont restées, comme l’étanchéité de la coque, le lecteur d’empreinte digitale, le capteur de rythme cardiaque et la dernière version de Touchwiz. Mais il n’y a pas que de bonnes nouvelles, comme nous le verrons. http://www.lesmobiles.com/actualite/15432-test-du-samsung-galaxy-s5-mini-un-mini-qui-n-est-pas-si-light-que-ca.html Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
-Philippe- Posté(e) le 26 février 2015 Auteur Signaler Share Posté(e) le 26 février 2015 La filiale française de Samsung a indiqué sur Twitter que la mise à jour vers la nouvelle mouture d'Android aurait lieu au 2ème trimestre. Ses utilisateurs devront donc attendre entre avril et juin pour pouvoir en profiter. Samsung est l'un des fabricants les plus actifs en termes de mises à jour à jour sur Android. Le problème, c'est qu'il dispose d'une gamme très large de terminaux, et nombreux sont ceux qui sont toujours en attente de leur passage sur Lollipop. C'est d'ailleurs le cas du Galaxy S5 Mini. Une date communiquée par Samsung France Jusqu'à ce jour, aucune information officielle ne pouvait nous indiquer quand arriverait la nouvelle mouture d'Android sur le Galaxy S5 Mini. Seule la filiale finlandaise de Samsung évoquait sur son site Web que le terminal devrait bénéficier d'Android 5.0, mais aucune date n'y était précisée. L'information nous est parvenue hier, et de notre chère contrée. En effet, le compte Twitter de Samsung France a répondu à l'un de ses utilisateurs qui souhaitait savoir quand aurait lieu cette fameuse mise à jour. Une réponse dans laquelle le fabricant évoque le second trimestre 2015. Samsung France Twitter - Galaxy S5 Mini Lollipop Une mise à jour qui tarde à arriver Nous pouvons tout de même nous étonner de ce délai puisque le Galaxy S5 Mini dispose de la même interface que celle du Galaxy S5, qui a bénéficié de la mise à jour il y a quelques semaines. Même remarque pour le Galaxy S5 Active, la variante robuste du flagship, dont la dernière mise à jour faisait passer d’Android 4.2 à Android 4.4. Ce qui semble mauvais signe pour ses utilisateurs. Les utilisateurs du Galaxy S5 Mini devront par conséquent s'armer de patience pour enfin bénéficier des corrections et nouveautés apportées par Lollipop. Cette mise à jour devrait en effet apporter une seconde vie à leur smartphone en stabilisant l'interface, mais aussi en s'accompagnant d'améliorations touchant les notifications, la sécurité, les connexions et l’autonomie. La version de Touchwiz sera elle aussi revue et corrigée, pour un rendu plus léger et plus épuré. http://www.lesmobiles.com/actualite/16981-samsung-galaxy-s5-mini-android-5-0-lollipop-prevu-au-2eme-trimestre.html Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
