Nokia 701 – the brightest screen in the world
http://www.youtube.com/watch?v=oay4yqRQuVE&feature=player_embedded
The second of our smartphone announcements today, the Nokia 701, offers excellent graphics performance, a refreshed UI, great battery life and the brightest screen the world has ever seen. Find out what else makes the Nokia 701 so special after the break.
Like our other new smartphones today, the Nokia 701 is powered by Symbian Belle and a 1GHz processor. It’s got a pentaband radio, with HSUPA 3G, WiFi, NFC and all the other standard features on our new smartphones like Bluetooth, GPS and FM radio. It measures 11 x 56.8 x 117.3mm and weighs 131g.
But it’s the touchscreen display that makes the Nokia 701 stand out. This is a 3.5-inch IPS LCD display with ClearBlack technology, creating a great combination of excellent brightness and contrast – it’s in fact the brightest smartphone screen to date (in terms of NITs). Of course, as with all our new smartphones, it’s wrapped in Corning® Gorilla® Glass, so you don’t need to worry about its sturdiness either.
It’s not all about good looks, though: there’s real horsepower as well. Behind the screen is a brand new graphics co-processor, with a faster clock and four times the graphics memory of previous Symbian smartphones.
There’s an 8-megapixel full focus camera with a dual-LED flash on the back, and there’s a secondary camera at the front for video calling. Inside there’s 8GB of user memory, with provision for up to 32GB extra storage using a MicroSD card.
All this functionality doesn’t mean that you’re left with a phone that can’t see you through a working day, though. The battery is rated at up to 17 hours talktime over GSM or up to 550 hours on standby (8.8/504h over 3G).
The Nokia 701 will be available in steel dark, silver light, amethyst violet, and white variations and is expected to come to market in the third quarter of 2011. Before local taxes or operator subsidies, it will cost around EUR 290.
source: Nokia Conversation
Ecran lumineux sûrement (ça c'est pratique en extérieur :( ), mais en tout cas un peu faible en résolution face à la concurrence : 360*640px pour 3,5". :grin: C'est quasiment sûr que les fans de grosses résolutions vont critiquer ce modèle. :cry:
Bon il a quand même un APN bien placé et un bouton dédié ce Nokia 701. smile.png
Non mais la couleur en plus... C'est à gerber...
Pis c'est de nouveau des capteurs eDof ? Si c'est le cas ils sont cons...
Le seul avantage que je vois c'est l'écran IPS, cela apporte un confort non négligeable. Mais avec cette résolution, les avantages seront moins flagrants.
Il existera aussi dans d'autres couleurs ( comme la plupart des nouveaux Nokia )
Et s'il reste à 290 Euros ( sans bonus operateur ) ,en nu , c'est très compétitif et avec une bonne autonomie qui manque cruellement chez d'autres constructeurs .
Les specs détaillées:
Key hardware features
* 117.3 x 56.8 x 11mm, 131g in weight, 64cc by volume; monoblock touch form factor
* 3.5" capacitive IPS LCD ClearBlack touchscreen; 640x 360 pixels resolution (nHD). Nokia says this is the world's brightest mobile phone display in any smartphone.
* FM transmitter (Play via Radio) and FM receiver
* NFC (Near Field Communication) with Tap and share / Tap and connect
* Active Noise Cancellation, which delivers clear sound in noisy environments (second microphone is near battery cover catch)
* Processor: ARM 11 at 1GHz with 2D/3D Graphics HW Accelerator (OpenVG 1.1 and OpenGL ES 2.0), RAM: 512MB
* 8 megapixel full focus (EDoF) camera (with dual LED flash); video capture at 1280 x 720p (HD - 720p at 30 frames per second), 2nd front camera for video calling
* Integrated GPS with location support for A-GPS, WLAN and Cell-ID location techniques.
* Compass (magnetometer), accelerometer, proximity and ambient light sensors.
* microUSB (USB 2.0) for file transfers, charging and USB OTG.
* 2mm charging port
* 3.5mm Nokia audiovisual port (stereo audio out and composite TV-out)
* BL-5K (1200mAh) battery with easy access battery cover (standby time of 23 days and talk time of 17 hours (GSM) and 6.8 hours (WCDMA).
* WCDMA 850/900/1700/1900/2100 (pentaband 3G) and GSM/EDGE 850/900/1800/1900 (HSDPA Cat 10 - 14.4 MBps, HSUPA (Cat 6 - 5.76 Mbps)
* WiFi: WLAN IEEE 802.11 b/g and Bluetooth 3.0
* 8GB mass memory and microSD card slot (supports sizes up to 32GB)
* Available Q3 2011 in Steel dark, Silver light, Amethyst violet and White
* In box contents: Nokia 701, Nokia Battery BL-5K, Nokia Connectivity Cable CA-179, Nokia Headset WH-207, Nokia High Efficiency Charger AC-15 and NFC gift card linking to Ovi Store apps (selected markets).
Key software features
* Runs Symbian Belle (Symbian^3 with second major software update)
* Symbian Belle additions and updates include a new look UI and homescreen, a pull-down notification system, updated applications, simplified software update system and richer NFC functionality. More details are available in our separate Symbian Belle story.
* Belle also brings significant performance improvements, with faster and more intuitive interface and smoother multi-tasking.
* NFC versions of Angry Birds and Fruit Ninja (unlock additional content by tapping another NFC phone) pre-installed.
* Ships with Nokia Maps 3.6 (free lifetime car and pedestrian navigation).
* Ovi Store for downloading additional applications and personalising the device.
Je rajoute que "Joikuspot" sera installé de série , suivant les marchés , et en principe pour la France pour les versions nues ; donc fini le double abonnement téléphone +clé 3G . :(
A+
